Hello all,
Just wondering does anyone else have one of these winches? And can you get parts for them. I found it in a skip! I cant get over how much it can pull. :thumbup:
HI MATE what weight will it pull mate and what size saw do you need thanks jon :thumbup:
What we have here is a Zollern pw17 muli exellent piece of kit i run mine on a husky 362/372 ample power it will officialy pull slow 1.7t fast .45t
60 metres of cable , they have a rep in GB I will find it up they are not cheap
nor are spares . any more questions i will be happy to answer
under the plate on the slow fast control there is a set of notches that the different speeds engage into these notches will round of stopping the selection of h/s or s/h , they can be filled back into shape with caution , the way to stop this problem is to never move the s/h lever ethier way with any tension on the cable , to remove tension move the brake lever push down on cable to give slack release brake then change s/h knob i dont know if that makes sense .
