I took a sample last night of the fungi pictured from an old oak i recently worked on. The fungi was found at approx 40-50 ft. It was growing in a shallow cavity where a large'ish branch had died back which i removed leaving the callus intact. There was soil-like material present in the cavity.
I went back up the tree last night to retrieve a retrievable ART that didn't want to be retrieved on the day of work!
Sorry about the quality of the pictures, and the semi decomposed state of the fruit bodies which i forgot all about until now.
Any ideas what it is?
The narrowing of the stem at the base and colour makes it look like Collybia fussipies but that is generally found at the base of the tree. So no confirmation from me just comments.
Edited by Will Hinchliffe
spelling error
  • 3 years later...
I've just stumbled across this thread whilst searching for something else
Craig,
You should be glad you did, because otherwise you wouldn't have been told, that fungi with whitish gills and white spores growing at this height on oak are Mycena's, in this case M. galericulata.
Craig,
Thanks Gerrit :thumbup1:
Would I be right to think that due to the lack of info in my reference material (which has been updated since we last spoke!) with regards to M. galericulata it has little arboricultural significance?
Incidentally, I have to climb the same tree in the next week or 2 to check how she is doing.
As you aimed the Q at Gerrit I shall leave him to give you the Arb significance of the specimen.
However, if you have the time, it would be interesting to see the wound/cavity now.
Could you take a couple of shots ? :001_smile:
