I personally haven't used this system, is it any good:confused1:
What about change overs does in not confuse things:confused1:
I still use just the basics, which seems to be fine. Looks good, however looks arn't everything.:001_tt1: you have to see if it has a good personality.Lol
When the guy pulls to show how the hitchclimber setup will advance the schwabish, it looks like there is too much pulling before it advances. I know you can use different lengths of friction cord etc but I always find this is the problem when setting up a self tending system and I always revert back to advancing the hitch manually. Perhaps I've not had enough gear to play around with!
