shopping time! looking for some feed back on kit
no unfortunately not
i bet... like the ropeguide... they can with a bit of faff and imagination! :001_smile: but i rarely bothered with a ring saver before... if you were that bothered you could install a ringsaver and then put in your pulleysaver when you are up there :001_huh:
not much use then if you got to climb the tree to put it in.
Set static line, footlock or srt to anchor point, then set your climbing line and go to work.
You know it makes sense!
Yes thy can easily be installed from the ground. Just install them the opposite to normal so the unspliced end goes through first bro
