I quite fancied one of those telescopic Stein retriever thingummies but to be honest I thought it a bit rich for me.
So, being a resourceful sort and having a shedfull of junk I decided to fashion one for myself.
It's a short telescopic paint roller handle from Travis Perkins which I straightened out a bit, cut a bit off, bent some more and then buffed the tip smooth with the Dremel. Length of accesory cord & a Stein tool clip in the other end et voila!
540mm long closed, extends to 920mm. Handle & pole are aluminium & hook end / 2nd stage extension is stainless.
Not perfect but I'm sure it will be just super for what I want!
Footnote:
Hook end is not the profile I was aiming for, was after something far more compact but, for the same reason that this contraption hasn't worked out as cheaply as it should have, I could only go so far before catastrophe!
it depends on the size of the vice i do have one laid about in the yard as i have a work bench with a 10ton one the chipper has a 1ton mounted to it and i have around the 5 ton one laid about in the yard
