husky 257, brake handle to close to front handle??
as above, brake handle is only 1/1/2 inches from front handle,can barely get my hand on front handle without putting brake on?? stripped brake and can see no problem there, bent front handle ??
I am assuming your chainbreak handle is the plastic one, if it is the metal one, just bend it a bit....after checking the AV mounts:lol:
If it is the plastic one, pull off the carrying handle and see if it bounces in to a bent shape as soon as the bolts are taken out. Had a large Stihl a bit like this and had to straighten the handle in a bench vice. Think it had been dropped out of a tree! Almost wrenched the bench off the wall:001_rolleyes:
