How to straighten out twist in boards
wisewood
After searching around for a solution to take the wobble out of some milled boards I came across this method using a router. Tried it today and I'm really impressed. Unlike a thicknesser there's no limits to the width of the boards you want to surface plane, and the cost of a router is WAY cheaper than a planer/thicknesser.
It also vastly reduces the amount of sanding too.:thumbup:
Chore !
There is also the Makita 1191B and a good level! Or just buzz it thru the jointer :D
:laugh1::lol:
Yup!
I'm guessing that 'd be a planer:confused1:
They were too wide to go through one and had already been cut into short lengths.
It didn't really take that long and they are wondrously level now.
I certainly wouldn't fancy tackling a massive board like in the second link though.
given, that second link is impressive. And got me thinking for a 10ft x 120cm board I will start on in january. A router is my least favourite tool. Perhaps I'm just rubbish with them.
the 1191b is a handy tool for planing. 110mm knife, and the adjuster is good, you can plane irregularities out in all kinds of ways.
btw, simon, using a jointer to level out boards that are too wide for the bed...
flip em round and cut from alternate ends - that gives you a cut of 52cm.
Good tip, the machine I was going to use was a 3 phase thicknesser but you couldn't feed anything over 12" wide into it. I need to 'lend' the use of a big jointer by the sounds of it.
If you're going to attempt routing that big slab get the biggest bit you can, I think they're called 'bottom cleaners':blushing::laugh1:
