I load everything by hand, unload everything by hand but then I'am not flat out just doing logs.
I would be looking to get a small cheap forklift to hang the bags on to load. Thats about as far as I would go, the mucking about you would do with a tractor and a bucket I could have a bag loaded.
Sent from my aye phone using Tapatalk
Do you season and deliver in the bags. We actually process into bags to season and tip into tunnel. I only do logs a day or so a week but in January I load and deliver 16 cu metres sometimes on Saturday alone. I load 2 cu in about 4 minutes I aim to load deliver and return within the hr so I can grab some lunch.
  • Replies 22
Cut and stack then bag over time, starting with the old first.
Yes and suppose the older you get the less keen you would be to throw logs for a few hours.
would be interesting to find out if other loadhandler users have a different mechanical method of tipping the bags out, there is a trick to it to make sure you don't ruck up the drag sheet.
Just come across this post - you've just coined a new Loadhandler slogan - "Hey", "What?" - "Don't ruck up yer Dragsheet" :001_tongue:
