Insane
smithers1603
The rope is tied off on top of the bridge, then thrown round underneath and pulled up the other side. They jump away from the bridge on the opposite side to the anchor and the rope is nearly at full extension and swinging them before they hit the end of the line vertically.
All that said, you wouldn't catch me trying it!
its usually called bridge-swinging i think. we used to do this off a viaduct in wales. two ropes both rock climbing dynamic ropes, and the trick is to run as fast as you can and jump out as far as you can that way there is less impact on the rope as your trajectory takes up the slack. makes sense in your head but not when your up there! interesting weather they binned the ropes after though, your supposed to after a massive fall like that!
