evening all, excuse me if the terminology is wrong,
the chainbreak on my husky apears to have engaged itsekf or i didn't disengage it when i took the side plate off and now i can't get the side plate back on. the band is to tight to fit over the fly wheel and i can't disenage it. is there a little trick to it? any pointers greatfully received.
thanks
tom
Sometimes you can clemp it in a vice with a couple of blocks os wood either side of where the bar stud holes are but generally it is easier to put it back on the bar studs and pull the brake handle back firmly!
