Multec 14ton Splitter
madmatt
Sorry for the delay in replying. The couriers were the problem, not the makers or dealer, both of who are great to deal with (especially Rob, the bloke listing it on eBay)
Machine is sturdy enough and works just fine on the back of the tractor, waist high bed might be ok if you are no taller than 5ft, but putting a pallet under the base sorted that out. It has been splitting everything from red oak to birch with no hassles, although it's new so shouldn't be a problem anyway. Got the four way head as well and one side table, again both solid enough and it's easy to change between two and four way split heads (six bolts)
Hope that helps m8
