11mm rope...hmmm
Chopper-Gooders
13 mm is good, i rate the xtcs, i think 11mm is too thin, unless you use a lockjack. One advantage of an 11mm rope is it opens up lots of possibilities to use gear mainly used in rock climbing, where 11mm is probably as thick as it gets. I switched from Yale xtc to poison ivy, which is 11.7mm the extra .7mm makes a hell of a difference to how the rope feels in your hands, i really dislike the blaze 11mm, i find it hard to grip, especialy when wet, but then i got some fair sized paws with which to have to grip it with. I started using 8mm prussik cord on the poison ivy, it worked well, but would heat up a hellish amount when descending, to the point where i could hold the knot, have just switched today in fact back to 10mm and from a knut to a VT, much happier i must say. - thats just my view and experience, best thing is to try and get hold of some of the ropes you are interested in a try em out.
