MS250 problem
Gloaming Tree Surgery
If the oil is getting hot in the tank then you must be getting thermal transfer from the cylinder head through the crankcase and to the oil tank.
I reckon your cylinder head may be dirty and have wood chips and oil covering the cooling fins stopping them dissipating the heat.
There is only one place the heat is coming from - the top end and muffler - I guess you may have a leak in the bottom of the muffler or it is somehow blowing exhaust gasses down on to the top of the oil tank - can't see it being much else - possibly worth fitting an Aluminium heatshield under the muffler - some saws have this as standard!
The 025 is a clamshell type engine - you may have lots of woodchip and gloop between the tank and the plastic oil tank transfering heat from one to the other.
