basic ropeguide
atree
isnt that what youve got mate? my one retrieves better than the webbing one..... i found that if the cocoon gets jammed in the ring it just takes a few flicks to dislodge it and sails through.dont get frustrated and just yank harder
I think atree is refering to the new RG's which use a soft eye instead of a ring and a plastic widgit to hold the soft eye open, they look like they should retrieve easy but have not tried one.
yes but its only wiv the cocoon and its prussic loop
Drew-im pretty sure my cocoon doesnt go through the lrg ring cos of the splice,will a large splice eye work instead??
http://www.treebuzz.com/forum/showflat.php?Cat=0&Number=134471&an=0&page=0
ive spliced a big open eye with shock cord inserted where the core was removed. it definetly didnt retrieve.at all. someone on treebuzz suggested making the rubber widget thing on a lathe so im gunna try making one soon. but i have no problems retrieving the cocoon and ring combo mind.
ok,well its definatly the wrong splice i have on the ring,you reckon take the core out and splice it flat on the ring?
yeah bro its a standard 16strand splice as per the samson instructions. get some spark, a bent coat hanger and its dead easy. if you wanna post the ring up ill splice it for ya..........:001_smile:
