larch cladding wanted york
Craig Johnson
Normal overlap is 1" so you're looking for 7" boards.
This may well be within the size range of commercial volume products - I'd try BSW in Carlisle - they definitely do mill larch cladding at one of their mills and in staggering volume - not sure on the max width they do though (8" from memory). They may supply you directly or put you on to one of their outlets.
You may well already know this, but if not, larch moves about quite a lot. The best way to handle it is to fix the boards with a single row of nails, placed about 2" up from the lower edge (so they only go through one board). This allows the top edge to be trapped by the board above, but free to expand and contract a bit which stops it from splitting. There's a really good page on installing cladding in the guide here:
http://www.the-edi.co.uk/downloads/architecturaldetailsfinal.pdf
Alec
