  Peter said:
If it's a pedal operated breaker, just put a brick on the pedal. Job done!
I have a price of wood that wedges between the cab and the pedal.
I run my splitter off my 1.5 ton kubota and it works very well, not the most powerful but nice and user friendly, barely uses any fuel and you can hear the radio over it.
  roseyweb said:
whats the difference between a breaker circuit and auger circuit?
I have both settings on mine, surely both are just squirty oil which is what is required
I assume breaker is the one for a splitter
auger circuit is double acting the breaker circuit is single acting with the breaker return going straight back to the hyd tank via the return filter if you are wanting to run a log splitter with an open centre valve this is the setting to use as it avoids contamination going thru the valve block and it will work better as when the splitter valve is in the neutral position the oil will just be sent straight to tank
Read more
