Hub
DrewB
Just another way of setting the hub up. Its attached to the access line witha girth hitch and access line tied off to base of tree. Other end still used for access. Working line runs through centre of the hub and acts like a cambium saver. The Hc gives it a 3:1 setup. Probably overly complicated but fun to play with on a sunny day:001_smile:
The DMM ring on the side of the hitch is so that i can keep the tail of my climbing line with me when using it in a 3:1 setup-just attach a revolver or similar into it.
