044??
240 or lower
BTW one guess!? you cna do better than that chaps.
200t or similar?
EDIT: should have said - complete guess
Very close and the best yet.:thumbup1:
  • Replies 36
Do you know what made me think top handle? Bearing in mind I know very little about Stihls at all - the angle of the spark plug hole :lol: Figured that it was hardly likely to be a husky TH as everyone says they are pants. :laugh1:
Powers of deduction :biggrin:
er - I said 020T:confused1:
Anyway - poor filter maintenance causes damage to the inlet (carb) side of the bore so if this wear is on that side only then it is the filter, if it is on both sides then it has just done its job and worn out through use.
I would need to see a bit more of the cylinder than that to make a call on the second one - the outside of it would help - hows about a 028 stihl
So you did.:blushing:
Only on the inlet so filter it is then.
Nope on the 028.
These might help.
[ATTACH]70627[/ATTACH]
[ATTACH]70628[/ATTACH]
That must be the Husqvarna 3120XP then - thought those ports looked a little good for an older saw:001_rolleyes:
RE - 020T - loks like cleaning the air filter regularly would solve the issue - dousing in hot water and one of these bubbling fabric cleaners is a good idea.
The other one looks like the plating has come off and the piston is bluing the surrounding area due to overheating - will be fine until the plating starts coming off above the exhaust port - your compression will drop off then and it will finally die:thumbdown:
Good to know that a saw can run with damage like that!
