does anyone know where i can get a 30"guide bar for dolmar 9000, it has a 13mm mount, also can the bar studs be changed to fit 009 mount, that would prob be best for me:001_smile:
Hi you say the saw has a 14mm slot mount which is a D033 oregon mount, i know Rob Dyer on here has a good secondhand Dolmar bar and he's close to you at Lymington.
You can also make a Stihl E031 mount fit by drilling the oil way hole to match as the slot size is the same from their 088, 084, 880 etc.
I also know of two dealers with 37" Dolmar bars in stock if interested, we don't bring these into Europe i'm afraid. PM me if interested.
Les
Area Mgr
Oregon Cutting Systems Division
does anyone know where i can get a 30"guide bar for dolmar 9000, it has a 14mm mount, also can the bar studs be changed to fit 009 mount, that would prob be best for me:001_smile:
I am a Stihl man and know very little about Dolmar, but anyway.
I believe you can change the studs such that it will take the D009 mount. If you remove the guide plate you should see there are two "additional" holes, this is where the other studs would go. However, in order to make the change you would need to also replace the guide plate and sprocket cover. More importantly though, I don't think you can get the required parts in Europe, if you look in the IPL the parts required to make it D009 are listed as USA, CDN, AUS.... Where i think it is standard.
It might be possible to modify what you already have though?
Do you have any 3001 or 3002 mount (both 14mm) Stihl bars you could try to see if the oil hole lines up? What about the one in your avatar?
