I am looking for suggestions for a split charge system, as i have a large deep cycle battery at the rear of my log delivery vehicle to power a palfinger crane. Plus I also want to run work lights and a additional power into the cab for a 12v fridge i have and a charging station.
Any suggestions?
I have found one i like the look of on ebay for £85 which has a battery charge indicator and there are a ones that are more functional that are probably just as suitable for around £50.
I've got one of RAW components voltage sensing ones on the 90, primarily as a fridge circuit. Dead easy to fit and been on about a year/20,000 and behaved itself.
Google them and it should come up :thumbup1:
theres not much to split charge systems. basically what you want to do is use the supply to the red battery light to work a relay that links your batterys together. ei when the light goes out there linked and charging both batterys
