Worst I have had was 2mm off! was a big job on limestone ,destroyed the blades,took them to a friend for Surface grinding,he set them up together and left them on until they came bak to a good edge, took quite a while……had an engineering company do them a few times but they would wait to do them until i would enquire if they were ready and only put a mild edge on them€ 70 a set!,my friend rebuilds engines, he just does it on the spot and gets them scalpel sharp and will square up the anvils well! mates rates….. A good square anvil is just as important…...
Its a bit more niche, but you could investigate sharpening stump grinder teeth. Information on sharpening greenteeth is quite hard to come by, and nobody is exactly shouting about offering it as a service on google!
Morbark chipper website has a tool listed called Bevel Buddy that allows you to sharpen 2-3 times on the machine before you have to pull the blades and do a proper sharpen. Looks promising for minor touch ups.
Worth sharpening chipper blades 'as a job'?
Probably not.
Mate of mine has an engineering firm and does mine, i think two thou at a time and the boys do a really good job. I know what his hourly rate is and what he charges me and i can't see how companies such as a certain Machine Knife company (that i will never use again) can do them for £6 each?
Regards,
Steve.
