Hi all
The missus wants me to spray her horse paddocks, I've got a quad and have been looking at sprayers.
I been looking at some of the cheepy ones on ebay and there cheaper than I thought but aren't pressurized I think.
Doe's anyone have any experience of these? Are they any good?
Cheers
James
xxx
i use one of the davies tractors ones (America imported Fimco), which has a high output pump on it, pressures the spray tank to 40psi then the pump only cuts in on demand so its not running the whole time if you using the hand lance. Decent 3mtr booms with proper nozzles that can be swapped, the tank also has the hand lance and a built in aggitator so you can mix the chemicals properly first mine is about 5years old and works faultlessly, and has heavy duty brackets for the booms
will it be living on the bike as they arent that quick to swap on an off, takes about 30mins to set mine up so the tank lives on the front rack so i can use it as ballast if i have the seed hopper on the back as well
I have one similar to that one but it has the wide spray single nozzle which is much easier to use near fences, trees ect & when going in & out of gates.
