  • Replies 32
I would use the composite boards 14mm is more than adequate but a lot depends on what kind of frame you intend putting them on.
Service Metals GRP Products-SAIRPS
It comes in white but will take paint easy as. Trying to match an ally finish that will tarnish and change over time will be a trick and a half. If you can get a colour match something like, paint the timber and lacquer the whole lot to seal the ally sides and stop them oxidising. Otherwise paint the entire thing whatever colour you need.
i would build the frame from around 3mm angle, put various lenghs of flat in for support and sheet it with 2mm galv.. rivet the sheets to the steel (easy to replace when the time comes) and seam sealer over joints to help lose any sharp edges
I have done the steel sheets in the past. They will show each and every dint and will look pants within weeks.
If you do go that way use zintex rather than galv, its weldable but won’t rust. Welding galv is nasty and riveting it just comes loose
Thats a good point about rivets coming loose.. if you get a nice fit with the sheets and plenty of support in the frame to prevent it being able to bow, i would say some decent rivets should be fine .
