  • Replies 45
looks like you have yours set considerably further away from yourself than i used to
i usually use it like this as a 120cm dyneema sling fits inside the kevlar rope protestor better than thicker slings i have mates that use a 100cm sling to make it shorter but i like the big long pull and dyneema slings are nicer coloured
Rich, Search for "Petzl Shunt" it is a relatively old mechanical ascender/descender design that works with both double or single lines. It works more like a friction hitch than just about anything except a Lockjack.
I don't suppose Arb type climbing counts as hours experience?
no it does not but more down to supervisory levels as you could modify your climbing to suite there requirments but would hate working that way in a tree
