Spoke to Keely
She says that the ABC Level 4 Diploma in Arboriculture will not be the same as the Tech Cert so there will not be any upgrade for existing Tech Cert holders to a Level 4
From what she said it seems if you want a level 4 then you will need to complete the Diploma (or you could go for the Level 4 Cert which is half the number of modules than the Diploma).
Should be on par with prof dip. When I sat the exam last year I was told it was going to marked exactly the same. That wasn't from a bloke down the pub that thinks he's Elvis either......Elvis has left the building.
