Hey guys just ordered some 16mm yale double esterlon lowering rope does any one know the working load. Any one on here have it how they get on with it.
I am hoping this is all the lowering rope i will need got 45m.
  • Replies 34
I use it all the time, its my main lowering rope. I've always had the 750kg figure in my head and thats the weight of my chipper! I figure I'm bever likely to be brave enough to cut something that weighs the same as my chipper and expect the rope and groundie/grcs to hold it!!
45m should be ok if not then a smaller lowering rope in a longer length would do as at 22m your are not likely to be rigging heavy stuff!
Heres some pics of it in action..
In this set up we were glad to have a little over 45m.
Take advantage of twin stem rigging whenever you can, it makes everything much smoother but does use up more rope.
To arrive at a figure of 750kg, you have to start with the average breaking strength (16,800lbs, 7348.19 kg)
10:1 SF, 750 kg ish.
I think HB are being a little optomistic.
I was under the impression that SWL should be calculated from the MBS rather than the average BS, but I could be completely wrong!
call it 650-750 ish then. you can't estimate a branch weight accuratly anyway so its all guesswork. 16mm is a good rope which will do most things, as long as you don't shock load it. Its all in the lowering device really.
