After some advice here.
Last year we were doing a site clearance and we found an old saw in the unergrowth.
Its a small bench type made by S Tyzack.
The blade is about 12 inches diameter so it would be OK for a 4'' cut.
Amazingly is spins fine - with a V belt pulley attached, the bearings seem to be pretty good.
Below the bed is a mounting plate which is adjustable.
I think it would be fine to use to cut up my own logs but what hp/wattage of motor should I fit? I have no 3 phase supply so am limited to 230v
Any advice from you industrial wizzards would be greatly appreciated.
Shane
Congratulations on the find and congratulation on sneaking it into the garden, that double duck disguise must have them well fooled.:laugh1:
As for the motor, I wouldn’t go less than 3 hp and aim for about 3000 rpm
