Thank you Dan, Rob...
Alright, last one, or i'll be giving away the Trollspiel designs that I only ever make one of... (and not strickly Alaskan related!)
This one, Ive been meaning to do for 20+ years, after a visiting an old man in the highlands who built his house on a diet of Fly Agaric mushrooms & an old Husky..
This weeks project. Hollowed out ash butt ( & bleeding knuckles from kickbacks! ). Put in the kiln and dried super quick to get it to check madly - and it has. And looking in good shape. There's a startburst of checks radiating out, which I will fill with black 2-part filler, sand to 400 grit, and then about 800 coats of lacquer. Im excited about this one.
Skipped it this year, but will have a stall at Kent County Fayre next year.
Great stuff!
Liking the furniture - wish I had the patience for joining stuff but an impact driver and bolts do a great job.
Ash butt looks good - but plenty sawdust and fumes I bet!
Thank you,Harvey. Method....
8" softwoods, run thru the thicknesser, biscuit jointed, glued & clamped. I use PU glue on that, goes off in 10 minutes.
With any designs, draw & them out on mdf first for a template. Cut them out with a jigsaw. Loads of rubbing down, and a dremmel to get into the peaks & corners.
Biscuit joint & glue the whole thing together - no lover of screws & nails..
