tachograph info
Johny Walker
If it's digital you need to get a digital tacho card from DVLA. It looks like a hydrid between a credit card and the new driving license. It goes in the slot and you follow the prompts.
Then it tells you it has a fault or that you are driving without a card. You press a few more buttons in a random order and it comes right. You have to get a downloader too as the card fills up with info quite quickly. I.e. weekly. If the card won't work it's usually broken so you have to send it back and get a replacement. Whilst you are driving without a card at the end of the day the machine will roduce a printout, which you keep for your records.
The other option is to rip it out.
Its not a digital tacho Paul, its an analogue tacho with a digital display, if that makes sense.
It should have a mode switch on the front, there will be 3 small symbols, one is crossed hammers, one is a square with a diagonal line through it, and one looks like a flattened "h", which is supposed to be a bed.
Crossed hammers is other work
Square is Period of Availability
Bed is Rest or Break.
Most or all modern tachos record driving automatically, so just drop a disc in and go. If you are working on site then you need to set it to other work, and make sure you record enough break time in the day.
You need to read up on driver's hours, its not too complicated, basically you can work for 4.5 hours then you need 45 mins break, then you can work for another 4.5 hours. There is more to it though, so do your homework.
One other little tip for you, always put your disc in 10 minutes before you leave the yard in the morning, and set it to other work, otherwise you will get into trouble for not doing daily walk round checks, or not recording your working hours correctly.
