  • Replies 43
they are WET logs ha ha, i hope you have some coal to burn the moisture out those bad boys:001_rolleyes:. I am with Hammy, Lime.:001_smile:
The rough bark ones are from the wider trunk hence being shorter, the longer one is branch wood, so a little longer. Bet you got them off a tree surgeon cheap:laugh1:
the reason
i asked was because when i put a couple in the logburner wet they burned straight away with no coal, very well and with good heat i was a little puzzled
the reason
was the fire going well before you put them on:confused1: if you lit a fire with them from wet, i want to know your secret.
Tony i thought they were Alder at first:blushing::laugh1:
