hi i have a 25 hp kohler engine on my chipper and it just doesnt like starting once its going its fine but on start up it seems to flood the plugs misfires a bit then runs normally just wondered if any one else has had the same problems thanks
I was recently told to turn off the fuel when the machine is switched off. This, apparently, stops a fuel flood whilst in transport.
It should not be valves as they are hydraulic valves and should not need any adjustment, may be wrong, check your supplier.
does any one know were i can get new engine if it comes to it hope not :001_rolleyes:
Universal Engine Power, in Dunmow, Essex. They fitted mine in 2008 and are a great company. good price too and was a better engine as it had an oil cooler etc:thumbup1:
