ha neither do i usually, try a pulley so it feeds the cam directly under the rope instead of at an angle..its really to help when limb walking ,with out the pulley it would make the cam jam or jerky as its coming from a harsh angle with out the pulley ...a pulley before the cam insures the friction of the cam will be smooth....if that makes sense??????
no it just makes limb walking easier...i found with out it on long limbs the rope had a tendancy not to be smooth infact it almost jammed unless you fed it...a pulley just does the feeding for you.
A lock jack runs very smooth when working verticle almost to well! not so great when limb walking wich is why i switched back to a vt
