  • Replies 20
Sam can I ask a favour. If you find yourself next to your truck with a tape measure. Could you measure from the back of the cab to the end of the chassis. The extra cab has a better load cap by 500kg over the single cab. I am thinking of getting my tipper body put on one. I did a cheapo job on an old hilux with a new body with the intension of putting it on a newish truck if it proved itself. Its so far been indestructable but there is only so much abuse a 12 year old truck will take.
I thought the single cab would have more load space :confused1:
I will let you know:thumbup1::thumbup1:
That doesn't make sense :confused1:
I know . You would think the single cab with a much bigger body would match or have a greater weight capacity than the double cabs but it does not and never has. My mark 4 gross kerb weight 2550kg unloaded 1750kg roughly. :confused1:
It's because the double cab carries more people or equipment plus the load bed weight.hence heavier duty sprigs and hangers etc and bigger load rating
and general grabber I got sick of replacing the rear ones every six month on our d22...
