  • Replies 43
  • 1 year later...
what about descending on a italian (munter) hitch ?
it works in the same way as a fig 8, i think and all you need is a carabiner.
t
Going back to the thread, always check your line is clear as you reposition in the tree. For most trees I use a 20 metre rope even the large ones. Mainly through choice but partly cos I cut it in half. Does tend to make you more careful when you know you can't reach the ground with your rope.
Generally, if you need to make a rapid descent, emergency or hot totty, use prussik and only touch it with your fingertips as it gets warm quick.
For those of us who aren't called Mr. Moneybags and find it hard getting used to VTs, I run a distel. Which is a bit like a VT just with one less wind at the top but one leg goes around the host line once and over itself below the 3 twists.
I find it much less finicky than a VT, especially being a new climber, but still binding well and releasing easily =)
