Just as a thought and not wanting to be negative.
How would a system like this be seen from an employers or a HSE point of view.
I believe concerns over best practice and approved methods need consideration but will totally agree the industry needs look forward
  • Replies 44
good point, hard to say, but it is a solid rig, and when backed by a stopper knot, pretty much fool-proof.
that is why i like my boss, I look back at him every morning in the mirror:001_cool:
One more short vid to show the set-up, but dayum....it was cold...-35c :) but I love this thing so much I wanted to share with you guys ;) lol
this one shows the set-up to footlock the doubled access line with the SW replacing the the prussik and the rigged DRT line replacing the tether.
How do you retrieve the foot lock line?
Use a longer SW, tie it in a VT/MT or similar, tie a separate stopper knot in each leg of the FL line. Retrive the SW as you would a normal 2 ring cambium saver, pull the FL line out.
yep :)
or you could just descend on an "8" backed up by the SW.
but that entails going back up to it.
