Stihl ms880
Cackhander
For the last couple of years (since the theiving wossernames had it away with my 076) I've been making do with a ms460 with a 25" bar. Over the next couple of weeks I've got some big oaks to "bust apart" for milling and I've come to the conclusion that I'm going to have to bite the bullet and get myself a big saw. I've been looking at the ms880 with a 4ft bar. Does anyone one have comments / opinions on the saw?
Cheers,
Ed.
Hi, the 880 is a beast but a wonderful beast. i use one all the time for milling. the only bits of advice i can give you are (a) check out Rob D Alaskan Mill for Bars. (b) when starting the decompresion button can pop out and cause some problems(painfull) the way round this is to push the button in, put your left foot in the handle and your right foot on top of the engine over the decom button and pull the starer rope with both hands. © keep some spare sprocket barings.
these are just my thoughts but all round it is a bril saw.
Are you actually milling timber with the saw or just processing it ready for milling?
If you are milling with the saw then the more power the better, and the weight is neither here nor there.
If your intending to use the saw regularly for cutting then I would go for a 660 as it is powerful enough to do any regular tree surgery work, but not so heavy that you will struggle with it up a tree.
