Hallo,
anybody can give me some advises about the cambium/friction saver? I would like to buy one and not sure which size is optimal (is it better shorter or longer?), which type, company...
Any help?
Cheers a lot!:thumbup1:
Hi turkey oak theres loads out there to buy i have a buckingham one good bit of kit the longer the better in my eyes just double wrap on smaller stems i also have the art pulley cambium so easy to climb on if u have the money treat yourself hope this helps
Hi Turkeyoak, some of the cambium savers are fitted with a small ring and a bigger one. This is probably the simplest configuration.
One of mine is a Petzl Treesbee - it has a large ring on one end and a maillon on the other. This allows for more adaptation eg. fitting a pulley to the maillon so that friction is decreased.
Have you had a chance to try any out?
i got one of those sirrus mutlisavers there really good as you can change the length of it which comes in very handy.Make sure u get the longest one tho i think its the 1.50 meter ones.
I started out with a standard simple cambium saver with a ring on both ends, one slightly smaller for retreival.
I have had the ART ropeguide since last summer, very expensive to buy, but many climbers make their own version at a fraction of the cost. Good bit of kit tho, saves a lot of energy when ascending! The beauty of this bit of kit is that it has a pulley to eliminate friction, as well as being adjustable like the Multisaver. I would definately buy something adjustable, it is very useful in certain circumstances.
If money is no object buy the ART ropeguide, otherwise the multisaver is a good bet.
