Hi,
i worked for Renault as a Renault technical expert for 17 years , if you get the type number that is on the vin plate (four characters) i will check in the data book for you . :thumbup1:
Not sure of this van is it transit 3.5ton size!
If so its not want it can pull but how long will it pull a machine which is to heavy on a day to day basis, with a load of woodchip or logs.
Think you would be best to stick to a machine up to 1000kg only if you passed your driving test before oct 97 I think or around that time.
When did you pass your driving test as i am sure you know that will affect the weight you can tow (boring i know)
What chipper do you have or are you looking for the right machine.
Regards
Wattie
