Too addictive monkey-d. But well worth it.
Matt you photoshop it buy opening the photo in editor then going to layers, duplicate layer, the go to enhance, convert to b&w, then go to eraser icon and use block for the big bits, brush for the edges, once finished go to save as, change the format to jpeg.
Job done.
Job done.
cheers mate, however when i used the eraser it just turned it pink, any suggestions!?
Your using eraser not spunge? It should just cut through the black and white layer? is it on full edit? :confused1:
