Has any one got any idea on what could be wrong with my timberwolf 190? I cant get the antistress working. Had a similer problem a few years ago with a tw150 and it was the sensor on the engine. I,ve had the tw190 in bits but cant see any stress sensor and cant figure out what it could be.
Hi Smithers. Slide off the side panel on the ignition switch side and right in the middle you'll see 2 plastic 2cm cubes with cicuitry in them. To see if these sensors are working, fire up the machine and open the throttle. Press the 'In-Feed' button and the top cube should show a red LED glowing inside. Press the 'Reverse' button and hold it, crane your neck around (unless you have an assistant!) and the bottom cube should show a red LED. If none of the above happens, then my guess is those sensors are the root of the problem.
Having said all that, if you've got lovely sharp knives and feeding shorter or thinner bits, then the No-Stress won't kick in anyway!
  • 3 weeks later...
