  • Replies 24
thanks for all the info guys!! it is coolant as it's bright red against the snow!! the leak is on the driver's side about half way back?? i ain't had time to fully check.. it runs fine no overheating get's up to temp and all but still it leaks?? and it hasn't have a/c
id be having a look asap, it'l only get worse, not better!!!! get a garage to pressurise the cooling system if you cant find it, [5 min job!]
so am i right in thinking you have a steering related squeal and a red fluid leak that doesn't affect the coolant level? sounds like a powersteering fluid leak to me
lol!! is your coolant pink/red type or blue type???
