new processer
After a lot of research and talking to suppliers i think for the arb waste i am processing a circular saw bench with conveyor is going to be the way for me to go. If i were processing large lengths of cord wood then a processor would be great but i am not.
So this leaves me with a choice of saws.. ideally i want one powered independently so i do not have to use my tractor to run it.
Anyone got any suggestions?
  • Replies 23
I have been looking for a single phase 4m conveyor but they seem to start at 2 grand. I cut alot of planed timer to 6" for kindlet so would come in useful for that if you come across a cheap conveyor that does not suit you could you let me know.
i have only used dalen and posch machines and would deffinately recomend the dalen there so easy to use and are well built
across the two types chain v circular saw
the circular saw models are best on soft wood as any slight bend and they jam where as the chainsaw doesn't in my experiance get jammed as easily
also chains can handle larger diameter timber but other than cutting speed maintanence seems about the same time wise but circular saw costs more as you can't home sharpen
either way its easier just to run multipli chains\blades
