Here is the Husqvarna recall info.
I never seen a recall on carb Walbro HDA, I just know it was replaced with a Zama C3-EL42 and cost here is $40-$50 for carb. The original 357-359 Walbro 199 was the worst of the bunch with issues.
Service Bulletin for 357XP, 359, 353, 346XP
This service bulletin is not new. I thought that there might be some out there who were not aware of it so here it is. If your saw has a black plastic clamp around the intake right next to the cylinder it is applicable to it. If the clamp is of steel construction then you should be ok.
B0600023
SERVICE
*537 43 88-01*
*compl 537 25 13-02
English 1 (1)
SB, 357 XP, 359, 353, 346 XP,
Partition wall and clamp for intake system,
2006-03
The existing intake system on 357XP, 359,353 and 346XP currently consists of an integrated plastic clamp in the partition wall. As the clamp is made of plastic, there is a risk of deformation. This results in impaired clamping force against the cylinder, which in turn can result in leakage in the intake system. To prevent this from occurring, we have now introduced a metal clamp and a new partition wall.
The new partition wall is made up of polyamide with 30 % fibre glass.
The new clamp is a hardened steel clamp. The new material and the design of the clamp reduce the risk of deformation and the subsequent risk of leakage.
Full replaceability prevails.
Introduced from serial number:
357XP 061100201
359 061100001
353 061100001
346XP 061100001
New part no. Description Excl. part. no. Remark
537 25 13-02 Partition wall, intake, complete New spare part
537 43 88-01 Clamp, intake New spare part
Spare part, partition wall, part number 537 25 13-01, has been discontinued and is replaced by part number 537 25 13-02.
  • Replies 31
Mowmaintenance in Stoke. However I did buy the 357 second hand but it shouldn't matter if it is a recall.
Absolutely right, I'll have a word.....
