The valve and electrode on plug is not same material.
This could work just fine, time will tell.
Just thought I let you have some experience...
Here is a bad pic of a decomp valves hole in side mounted cylinder.
It is same in top mounted, of those I have seen so far anyway..
Preassure escape small hole in to a chamber were valve sit better protected.
why do you need a decompressor in a 281?
been snowed off all week so i decided to fit a decompression valve aid starting as it has a fair bit of compression i have never had a barrel off a saw before but they are quite easy to strip down :thumbup1:
1) He was snowed off.
2) It has a fair bit of compression.
3) Its always nice to experiment.
Be sure to tell us if it works (or, more interestingly, if it doesn't)
:dito:
and also because i can
