Danequip stumpgrinders...
Ty Korrigan
As above.... great for small to medium size stumps, and will get you through a big one with a bit of elbow grease. If you have a lot of big ones to do, probably be better with a bigger machine. Used to work for a lad who had a pretty old one. Looked like it had taken a fair bit of abuse and still going strong.
I had one, but much preferred the Rayco with its bigger wheels, the smaller diameter but wider Danequip wheels make grinding hard work imo, but you can access narrower gates etc with the Danequip [with change of wheels], so bit of a catch 22, all manual grinders need a ply board under the wheels tbh to stop you from rutting, makes for easier grinding too
Edited by Lee Winger
