346 xp chain tensioning problem!!
richyrich
i have just assembled my new 346xp. i cannot get the chain correctly tensioned - when pulling the chain by hand it is putting tension on the rear sprocket- it is pretty hard to pull, but the chain can easily be pulled slack about an inch beneath the bar.
when you pull the chain it soon tightens up again- way too tight.
if you pull the chain backwards it moves easily as it should- with no strain on the sprocket. but the slack below appears straight away. pull it forward and it tightens again.
the 'side plate'/ chain brake cover is seated correctly, and the adjuster is in place.
the rear sprocket has quite a bit of play, but i assume this is correct, although i cannot think what else it is.
slackening the adjuster does not seem to ease the strain on the sprocket- it just gives more slack chain to drop, yet chain still does not pull. all strain seems to be on the rear.
i started the saw briefly to see if that slackened it up, but it seemed reluctant to shift the chain freely.everything is new- bar, saw and chain
any ideas welcome, thanks!!
  • Replies 27
Is it seated properly on the sprocket?
i have tried it about 20 times today as i did wonder this myself- same problem every time.
i could not get hold of dealer today- corwen forestry who are very good,
i will ask them tomorrow as its a real mystery, thanks
i have tried it without the side/brake plate off, whilst holding the bar in place- same problem!! thanks
Er, this should bear no consequence or have Husq gone back to an outboard clutch?
Sure the chain is the right guage - runs smooth in the bar rails yeah?
Edited by TimberCutterDartmoor
