Timber Dragon Trailer??
woodland
They are chinese but not that bad for the money. If you work on the basis that the hydraulics are almost disposable and then replace them with european sourced parts as required it could be a feasable investment.
If it was getting used commercially I'd tend to spend a bit more and go for something a bit more robust.
What you looking to tow it with?
A small 40hp Kubota off road but the appeal was the tipping trailer which I thought would be good for log delivery etc, in which case it would be towed by a ranger. Someone on here mentioned logic trailers but I wonder are there any other commercial options preferably European?
If you were considerign taking a timber dragon on the road behind a road vehicle then I'd have a good look into the legality before hand as I think you may find some problems relating to the lack of suspension and the nose weight
if you wanted road legal (as opposed to agri spec) and a rocking beam axle then as far as I know there is only one out there commercially but it's a lot more expensive than a timber dragon.
Thanks Chris, from the web site they claim that they are road legal brakes etc, but def worth investigating, do you know the name of the other company?
Ah The power of advertising on Arbtalk just saw Rikos version which seems a lot more sensible with adjustable axel position, :001_smile:
