superwinch h14
LisaB
We have the H14 on TD5's at work I may be able to get some pics of the drive shaft route (if i can find some where half clean) Also I was told by PG winches when they were still trading it was very simple to convert to HYD power. You can mount a motor where the steering box would be on an LHD vehicle then run a short shaft to the winch. Not a huge job to remove from a vehicle either well worth the effort
  • 1 year later...
Hi, sorry to hijack your thread, but I have the option of a H14 :thumbup:(off a LR 200) I have a couple of questions. Will it fit a s2a without too much drama, it comes with a winch bumper? Will the pto shaft fit? Will it be too heavy, I will change the wire for synthetic rope? Finally, the leaver to disengage the drive to pay out the rope has broken, does anyone know if it easy to remove so I can weld it back on?
Thanks in advance for any advice.
