Dear Chipper lovers,
Can anyone reccomend a preferably entec/timberwolf chipper repair business in and around north london. I need the feed roller blades changing and i understand you have to weld a nut on the bolts to remove the threads.
Thanks for your replys
Chris @ Tree Wise Men
No need to weld a nut on the ends of the bolts,just buy a decent allen key on a 1/2 inch drive socket, with a decent length extension that should do the job.
I am in Waltham Abbey if you need a hand.
Patrick
Not always that straight forward, the allen heads have a tendancy to round off. The bolts are glued in. So be prepared to get the welder out for one or two.
A bit of heat might help and maybe an impact driver to get them moving.
If your not into that try Roger at Hempstead Plant in Kings Langley, although no longer a Timberwolf dealer he was for many years and his lads are very experienced with all things Timberwolf.
