  • Replies 20
It depends on the hydraulic fluid power (pressure vs. flow) you have available,
L/min flow * bar pressure / 600 = power in KW
1HP = 746W
you old Unimog would have had ~18.5HP of fluid power.
my old mog had an extra pump on it, there was a button i was told never to press lol. Its my tp250, it needs 100bhp, so what oil pressue and flow would i need ?
that was the dual circuit hydraulics, meaning you had 45L or 55L per min flow on circuit one and 18L/min on circuit two, there would have been 2 buttons on the dash, one to turn circuit two on and the other to switch flow between circuits.
You would need ~75KW, you would then need some reserve for efficacy factors so you would need about 90KW
You would need ~263.4L/min @ ~205 bar for ~90KW
if you need a shot of a flow meter give me a shout im in the falkirk area have done quite a lotof oddball stuff like this mainly on excavators and crushers etc:thumbup:
I wouldn't know what to do with a flow meter:blushing:If you are good with hydraulics and fabricating and like doing things a bit diferent then i could keep you busy:laugh1:
Appreciatte the offer:thumbup1:
